Jeux, jouets et Lego : le deuxième à -50% (large sélection)
MATEZ-CA !! du lourd !! Tekin RX8 1/8
+22
Géronim0
edgar
delichoc45
Model Concept France
maxxou94
jejebrl
hormann10
gachettesoudé
djtuneman
squall
e-mike
smalldragon
arthur67
savageman
nitromaxx
26 participants
Page 1 sur 2 1, 2  Suivant
MATEZ-CA !! du lourd !! Tekin RX8 1/8 Empty MATEZ-CA !! du lourd !! Tekin RX8 1/8
Message par nitromaxx Mer 24 Déc 2008 - 13:18
j'en croit pas mes yeux, matez la bete !!
le nouveau controlleur tekin : 210A continu !! Shocked Shocked Shocked Shocked
[img]MATEZ-CA !! du lourd !! Tekin RX8 1/8 Tekin-10[/img]
Tekin’s RX8 is big power in a small package. Based off of the proven RS series Speed Control the RX8 takes large scale current demands in stride. Leading the industry not only in power handling ability but size and features with Drag Brake, Neutral width, Throttle Profiles, Voltage Cut Offs for Lipos and much more. The RX8 sits at only 1.5 x 2.22 x 1.46, a small foot print making it easy to install on any chassis. Don’t negotiate the track, attack it with extreme prejudice.
Easily Access All Programming, Anywhere, Anytime
Drives Sensor/Sensorless Brushless and Brushed Motors
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
PC Interface for Custom Programming
HDAC: High Density Copper Fet Boards
Sensor Plug for Precise Commutation with all Motors
Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Adjustable Drag Brakes
RS-232 Digital Communications Protocol
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™️ Programming
One-Touch Radio Calibration
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (7 steps)
Throttle Profiles (7 choices)
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2s, 3s, 4s, 6s, Custom)
Timing Advance when used with Tekin Hotwire
Extensive Tuning via Tekin HotWire PC Interface (sold separately)
Controls: Forward/Brake/Reverse
Input Voltage: 6S Lipo
Continuous Current: 210 Amps
BEC: 6.0V/5.0A
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Throttle Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4"
Weight Approx: 2.7oz
allez-y vous pouvez pleurez ! affraid
nitromaxx
nitromaxx
Nombre de messages : 1147
MATEZ-CA !! du lourd !! Tekin RX8 1/8 Empty Re: MATEZ-CA !! du lourd !! Tekin RX8 1/8
Message par Jiper Mer 24 Déc 2008 - 13:50
Mouaip and the price ? malheureusement bobo je pense Very Happy
Nombre de messages : 1372
Message par JSR74 Mer 24 Déc 2008 - 13:57
Il est enfin sorti. Depuis le temps qu'il le préparais.
Très intéressant en tout cas. (Dommage qu'ils ne mettent jamais la puissance apparente que peux encaisser le contro.)
http://rcx-team.oldiblog.com/
Message par nitromaxx Mer 24 Déc 2008 - 14:10
j' ai pas parlé du prix sinon tout le monde va fuir ! Laughing
non je déconne aucune info sur le prix... de toute facon vaut mieux pas au moins on aura encore de l'espoir Sad
nitromaxx
nitromaxx
Message par savageman Mer 24 Déc 2008 - 14:18
Un peu plus d'info et deux vidéo par là :
http://forums.radiocontrolzone.com/showthread.php?t=252859
http://www.teamtekin.com/video.html
Vu les prix des contros tekin pour 1/10 j'ose pas imaginer le prix des 1/8 affraid
Sinon quelqu'un sait si cette marque est fiable ? je connais pas du tout...
savageman
savageman
Nombre de messages : 332
Message par nitromaxx Mer 24 Déc 2008 - 15:28
tekin c'est vraiment trés fiable ! Very Happy
jamais vu de problemes sur ces contros... par contre trés cher Sad
nitromaxx
nitromaxx
Message par Christophe Mer 24 Déc 2008 - 15:34
Salut Tekin c'est du top matos, bien souvent assez cher, je pense que ça va être de grande qualité, surtout qu'en plus ils le préparent depuis un moment Wink.
Nombre de messages : 4356
Message par Fléau Mer 24 Déc 2008 - 16:06
Comme dis JSR, moi ce qui m'interesse c'est ça capacité de puissance apparente.
enfin roulement de tambour pour le prix lol!
Nombre de messages : 5386
Message par arthur67 Mer 24 Déc 2008 - 17:15
Perso 250€ ne me choquerait pas (comparé à un mgm16018 avec ventillos).
arthur67
arthur67
Nombre de messages : 216
http://arthur670.skyblog.com
Message par smalldragon Mer 24 Déc 2008 - 17:20
mieux vaut un vario un peu plus cher et fiable
qu'un moins cher et tjrs en S.A.V
je pense qu'il sera entre 180 et 250 $
smalldragon
Nombre de messages : 18
Message par nitromaxx Mer 24 Déc 2008 - 17:58
moi je dit plutot 250/300 $ Sad
nitromaxx
nitromaxx
Message par e-mike Jeu 25 Déc 2008 - 18:52
peut importe le prix moi je m'en achete un des que possible Wink
e-mike
e-mike
Nombre de messages : 65
Message par nitromaxx Jeu 25 Déc 2008 - 19:13
si t'as les moyens te genes pas ! tu nous diras quoi ! Very Happy
nitromaxx
nitromaxx
Message par squall Ven 26 Déc 2008 - 1:07
il l annonce a +- 300$
mais c est comme tout le reste quand il en aurront bien vendu le prix va chuter
squall
squall
Nombre de messages : 100
http://jikamodels.be
Message par josselin Dim 28 Déc 2008 - 19:07
à mon si il est fait comme le R1 ou le RS ca va être du haut de gamme en la matiere cheers Wink
ce qui est domage c'est qu'il disent pas si il peux accepter les moteur autre que les 2 poles genre poles type neu ou plettenberg Rolling Eyes
en tout cas moi j'ai un amis qui a le R1 pro et c'est vraiment top, un vrai régal au niveau des réglages, ne chauffe pas donc telment que je me suis commande le meme donc j'ai hate de le recevoir cheers
Message par Jiper Mer 4 Mar 2009 - 10:01
Different combo Tekin RX8/Redline T8 dispo en backorder sur Amain pour 335$
D'ailleur parfois c'est indiqué pour buggy ou truggy mais les Kv sont pourtant très proches dans certain cas bref je comprends pas trop sur quels criteres ils se sont basés ??
Pas si cher que ca au final par rapport au combo castle, et la c'est du sensored, voila en attente des retours des premiers testeurs
Razz
Message par djtuneman Mer 4 Mar 2009 - 17:31
Il fait envie Razz
djtuneman
djtuneman
Nombre de messages : 1449
Message par nitromaxx Mer 4 Mar 2009 - 17:45
c'est sur avec 210A continu Shocked
nitromaxx
nitromaxx
Message par gachettesoudé Mer 4 Mar 2009 - 20:42
Ah non vous avez vu la date d'approvisionnement en bas de page? 1er avril!!! C'est une blague.... argggg lol!
Ca va être dur de pas craquer, en plus il est pas si chère cheers
gachettesoudé
gachettesoudé
Nombre de messages : 691
Message par djtuneman Mer 4 Mar 2009 - 20:53
loool c'est vrai que j'ai vu avril mais j'ai pas fait gaffe au jour c'est sûr c'est l'arnaque What a Face
si j'avais un bon budget en ce moment c'est sur c'est direct un rx 8 mais dommage que le hotwire soit pas livré avec
djtuneman
djtuneman
Message par hormann10 Sam 7 Mar 2009 - 14:58
Sont ils déjà commercialisez...
hormann10
Nombre de messages : 82
Message par gachettesoudé Sam 7 Mar 2009 - 15:33
En précommande bounce
gachettesoudé
gachettesoudé
Message par thba66 Sam 7 Mar 2009 - 16:12
le MMM est largement suffisant pour équiper un buggy, truggy ou monster.
Plus puissant cela ne sert à rien ou alors il faut m'expliquer.
Message par Jiper Sam 7 Mar 2009 - 16:16
Oui mais le MMM ne gere que les sensorless par exemple, ce tekin sera compatible sensored Wink
Message par thba66 Sam 7 Mar 2009 - 16:27
ah pour les moteurs Feigao Very Happy
Message par gachettesoudé Sam 7 Mar 2009 - 16:36
Il se trouve qu'il y a des catégories qui consomme un peu plus qu'un truggy...
Genre ça... Rolling Eyes
MATEZ-CA !! du lourd !! Tekin RX8 1/8 Dscf0556
gachettesoudé
gachettesoudé
Message par thba66 Sam 7 Mar 2009 - 16:44
ah tu as quoi comme moteur sur ce truc?
ils délivrent combien tes accu?
Message par gachettesoudé Sam 7 Mar 2009 - 17:16
Ben c'est un peu mon laboratoire roulant lol! Je viens de virer le 1515 1Y car c'était vraiment trop juste à mon goût même en 6S.
Là je vais tester un Feigao 4576. Ils annoncent 3500W pour le KD45, donc ça devrait sortir un poil plus qu'avant. Maintenant un de ces quatre il va vraiment falloir que j'aille voir Monsieur Lehner :brushlessmania:
Pour les accus, j'ai remis des Nimh pour l'instant. Si dès fois je monte trop en ampérage, il faudra que je passe mes LiPo en parallèle, parce qu'il ne tire "que" 125A continue. lol!
gachettesoudé
gachettesoudé
Message par nitromaxx Sam 7 Mar 2009 - 17:47
putain un 1515 1Y en 6S ne te suffit pas ??!!
putain j'ose pas imaginer la vitesse du bazarre Twisted Evil
nitromaxx
nitromaxx
Message par jejebrl Sam 7 Mar 2009 - 18:20
c'est du 1/5 ?
ça doit être lourd très lourd même donc le 1515 1y il doit peiner un peu
Smile
jejebrl
jejebrl
Nombre de messages : 56
Message par gachettesoudé Sam 7 Mar 2009 - 18:23
Ben oui c'est qu'il y a dans les 8-9kg à pousser Laughing
gachettesoudé
gachettesoudé
Message par maxxou94 Sam 7 Mar 2009 - 18:37
WAOUHHHHH ! j'adore ce modèle en 1/5 bounce
je suis même étonné que le 1515 1Y ai pas cramé avant Laughing
je suis fan tu voudrais pas faire une petite vidéo Question Very Happy
maxxou94
maxxou94
Nombre de messages : 289
Message par JSR74 Sam 7 Mar 2009 - 18:49
C'est HS mais pour motoriser un 1/5 dans de bonne condition, c'est un ensemble de se style:
Lipo 12S 5000 mAh
moteur Neu 2215 2,5Y (600KV)
Pour le contro: scratch
C'est une config fiable, puissante et cher....
Message par gachettesoudé Sam 7 Mar 2009 - 19:06
Je sais, j'y réfléchie Wink
Le seul soucis c'est que ça coûte No En contro tu as ce qu'il faut chez MGM, hacker, ou schulze Twisted Evil
La vidéo? Oui un de ces quatre il va falloir que j'y pense What a Face
gachettesoudé
gachettesoudé
Message par nitromaxx Sam 7 Mar 2009 - 20:52
oué par contre niveau contro je ne te dit pas le prix affraid
nitromaxx
nitromaxx
Message par thba66 Sam 7 Mar 2009 - 21:16
En effet on est plus dans la même catégorie affraid
Message par Christophe Mer 18 Mar 2009 - 19:59
Salut à tous,
Petite news Razz :
Tekin bientôt dispo chez CBRacing prochainement, y a plus qu'à attendre la disponibilité et rentrer des sous pour financer la premiére commande Wink.
Les combos devraient être à nouveau dispo fin avril.
Je pense cibler sur le modèle buggy 2650 Kv et le modèle Truggy 2250 Kv, à mon avis le gros des ventes.
http://www.teamtekin.com/rx8.html
Moteur et contrôleur seront vendus en combos et au détail comme pour les Monster mamba max.
Message par nitromaxx Mer 18 Mar 2009 - 20:03
et je suppose plus cher que le MMM non ??
nitromaxx
nitromaxx
Message par djtuneman Mer 18 Mar 2009 - 20:23
mais le modèle truggy pourra prendre du 6S ?
djtuneman
djtuneman
Message par maxxou94 Mer 18 Mar 2009 - 22:16
nitromaxx a écrit:et je suppose plus cher que le MMM non ??
j'ai envie de dire logique Wink
mais je pense pas que sa sorte non plus a un prix exorbitant Laughing
djtuneman a écrit:mais le modèle truggy pourra prendre du 6S ?
c'est pareil j'ai envie de dire que avec 210amps si tu fait pas passer du 6s tu fait rien passer Laughing
bref vous inquiéter pas tous passe enfin presque , y a toujours un gars pour faire cramer le contrôleur l'exception qui confirme la règle disons Laughing
maxxou94
maxxou94
Message par djtuneman Mer 18 Mar 2009 - 22:40
oki je vais essayer du 8S alors Laughing
djtuneman
djtuneman
Message par Christophe Mer 18 Mar 2009 - 22:56
Vu le prix qu'on les raque, oui ça sera plus cher que le MMM ... Neutral
Message par CHRIS01 Mer 18 Mar 2009 - 23:02
gachettesoudée ta voiture est une formule france apparement donc tu as les freins uniquement sur l'arriere donc si tu conserve ce frein mécanique tu peux peut être regarder vers de gros controlleurs pas destinés a la voiture rc et surement moins onéreux ;pour les accus et le moteur en poids tu dois avoir de la marge car un zenoha 23cc ça pèse
Nombre de messages : 2183
Message par gachettesoudé Jeu 19 Mar 2009 - 20:12
CHRIS01 a écrit:gachettesoudée ta voiture est une formule france apparement donc tu as les freins uniquement sur l'arriere donc si tu conserve ce frein mécanique tu peux peut être regarder vers de gros controlleurs pas destinés a la voiture rc et surement moins onéreux ;pour les accus et le moteur en poids tu dois avoir de la marge car un zenoha 23cc ça pèse
Euh, erreur de casting il me semble... Ce n'est pas une formule France, c'est une Harm EP-1. Ce modèle était conçu pour être utilisé en électrique dès le départ. Il n'y a donc pas de frein mécanique dessus. Après quand je parle de poids, je parle pas par rapport au thermique, mais par rapport à ce que le moteur peut pousser; et là ça devient plus galère No
Bon sinon pour en revenir au sujet, au US le combo Tekin fait environ 40$ de plus que le Castle. Quand on voit les perfs annoncées ça ne me semble pas si chère. Après bien sûr il faut voir sur piste ce que ça vaux. Mais avec Tekin je ne suis pas trop inquiet cheers
gachettesoudé
gachettesoudé
Message par maxxou94 Jeu 19 Mar 2009 - 20:40
pour la harm ep-1 je sais que un ensemble contro + moteur très performant était sortit pourquoi ne pas l'installer vu que c'est fait pour Question
maxxou94
maxxou94
Message par gachettesoudé Jeu 19 Mar 2009 - 20:55
Très performant Laughing Le contro passe 70A continue, et le moteur est un Feigao 15XL What a Face C'est pas trop mon genre si tu veux Evil or Very Mad Je vient de passer le moteur sur mon D2.
Bon il y a eu aussi une version 100A continue, avec un moteur un peu plus long (110mm), mais c'est toujours pas suffisant à mon goût Mad
gachettesoudé
gachettesoudé
Message par thba66 Jeu 19 Mar 2009 - 21:04
il faut mettre 2 combos MMM/2200kv en 6s Very Happy
Message par maxxou94 Jeu 19 Mar 2009 - 23:31
gachettesoudé a écrit:Très performant Laughing Le contro passe 70A continue, et le moteur est un Feigao 15XL What a Face C'est pas trop mon genre si tu veux Evil or Very Mad Je vient de passer le moteur sur mon D2.
autant pour moi Very Happy
je me souviens il y a un an ou plus , un article était paru dans "rc racing car" le mec disais sa super performant alors je répète comme un mouton lol!
bref autant pour moi
et sinon pourquoi pas un 1521 ? voir un 1527 Question et si sa suffit pas un 2215 clown
maxxou94
maxxou94
Message par nitromaxx Ven 20 Mar 2009 - 19:26
lol un 2215 en 6S ta harm va faire des wheel... What a Face
aprés il faut le contro qui suit la Shocked
nitromaxx
nitromaxx
Message par Model Concept France Ven 20 Mar 2009 - 22:25
Oui, je me suis un peu renseigner sur cette marque et sur les nouveaux produits, et apparemment c'est du haut de gamme.
Je trouve également la réalisation superbe.
Nombre de messages : 225
http://www.modelconcept.fr
