Funko POP! Jumbo One Piece Kaido Dragon Form : où l’acheter ?
Hyperion EOS720I ou Icharger 208B ??
vttman4012
delichoc45
Hyperion EOS720I ou Icharger 208B ?? Empty Hyperion EOS720I ou Icharger 208B ??
Message par Pulse Lun 25 Mai 2009 - 20:24
Tout est dans la question. Ils valent tous deux 200$.
HYPERION:
"NEW! Hyperion EOS 0720i NET 7S 16N CHARGER, with Integrated LBA10A balancer, TCS and 250W charger power. Network to 500W and 14S max(2x7S balanced) - See Details!
The EOS 0720i NET is an extremely powerful (250W, 20A), versatile, easy-to-use charger with special features for speed charging lithium packs up to 7S*. 2C rates are possible even with our largest 7S packs. Integrated LBA10+ balancer has 300mA balance power per cell. Terminal Capacity Selection, PS Load Control, PC Dataport (PC software coming soon!), and User-Upgradable firmware round out this fantasitic package. But don't stop there: *two of these chargers can be Networked to allow charging two similar packs as a single unit, up to 14S total at 500W charge power. Nothing else on the planet offers so much power for so few $$ out of your pocket. Output Charge Cord/Connector set and Hyperion Balance Multi-Adapter for 2S to 7S packs are included."
ICHARGER:
"Capable of handling up to 350W or 20A charge rates. Lipoly, LiFe and Lilo compatible as well as able to charge up to 8 cell packs.
The iCharger is famous for its ultra-accurate balancing feature. Each unit is calibrated at the factory prior to shipping!
This is a quality precision charger.
Spec.
Input voltage range: 4.5 – 32.0VDC
Charge current range: 0.05 – 20.0A
Discharge current range: 0.05 – 20.0A
Maximum charge power capacity: 350W @ input voltage > 18V
Maximum discharge power capacity: 30W
Maximum extern discharge power capacity: 600W @ 30V/20A
Current drain for balancing: <350mA
Balance accuracy: <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count: 1 – 8 series (In non-balance mode, expand LiFe to 10s)
NiCd/NiMH battery cell count: 1 – 25 series
Pb battery cell count: 1 – 18 series (2 –36V)
Log Files storage: 16Mbit (36 hours)
Battery setup memories: 10
Intelligent temperature control: Yes
PC Connect: USB port
Weight: 420g
Dimensions (L X W X D): 143 x 97 x 26mm (5.63 x 3.82 x 1.02in)
Included.
208B Balance Charger/Discharger
2 Aligator clips
Banana leads
Temp Probe
CD
Note: Power supply not included."
Votre avis?
Idea
Nombre de messages : 3034
Hyperion EOS720I ou Icharger 208B ?? Empty Re: Hyperion EOS720I ou Icharger 208B ??
Message par thba66 Lun 25 Mai 2009 - 20:31
le chinois doit être moins cher que le Hyperion
Message par Pulse Lun 25 Mai 2009 - 20:34
thba66 a écrit:le chinois doit être moins cher que le Hyperion
Le prix est le même Wink.
Je parle d'après vous vu la fiche technique lequel semble être le meilleur choix?
Message par thba66 Lun 25 Mai 2009 - 21:00
http://www.progressiverc.com/208B.html rabbit
Message par Pulse Mar 26 Mai 2009 - 0:38
thba66 a écrit:http://www.progressiverc.com/208B.html rabbit
Tu peux argumenter un chouilla? albino
J'oubliais un détail important: c'est pour charger des Hyperion Generation 3 en 2x2S 5000Mah Cool
Message par delichoc45 Mar 26 Mai 2009 - 2:08
le prix n'est pas le même du tout! A peine 110€ le icharger! Je viens d'acheter les deux. Je préfère le icharger pour le moment mais je n'ai pas eu le temps de bien tester les deux. Les ventilos de l'hyperion sont pénibles alors que le icharger fais pas de bruit et on peut le mettre sur on/off ou auto. De plus, Il supporte 4,5v à 32v en entrée alors que l'hyperion coupe dès 11v et sur une batterie 12V de voiture un peut faible c'est vite chiant! J'ai fais une charge à 15A sur des 6S 5000 en 17 minutes avec le icharger il était tiède! j'en suis très content pour le moment.
delichoc45
delichoc45
Nombre de messages : 219
Message par thba66 Mar 26 Mai 2009 - 7:10
Et l'équilibrage? c'est bon?
Message par Pulse Mar 26 Mai 2009 - 13:18
delichoc45 a écrit:le prix n'est pas le même du tout! A peine 110€ le icharger! Je viens d'acheter les deux. Je préfère le icharger pour le moment mais je n'ai pas eu le temps de bien tester les deux. Les ventilos de l'hyperion sont pénibles alors que le icharger fais pas de bruit et on peut le mettre sur on/off ou auto. De plus, Il supporte 4,5v à 32v en entrée alors que l'hyperion coupe dès 11v et sur une batterie 12V de voiture un peut faible c'est vite chiant! J'ai fais une charge à 15A sur des 6S 5000 en 17 minutes avec le icharger il était tiède! j'en suis très content pour le moment.
Le icharger 208B? 110€? Shocked
Je veux bien le lien Razz . D'après mes recherches c'est sur ce modèle que je risque de partir Cool
Sinon reste la solution des chargeurs duo vu qu'il y a 2 compartiments à lipos sur l'e-revo Idea . Je pense qu'il est préférable de charger les 2 lipos en même temps non?
Dans ce cas il existe le 0610i duo 2 d'hyperion et le Graupner ultra duo plus 40.. Pas évident le choix d'un chargeur Embarassed
Message par thba66 Mar 26 Mai 2009 - 13:25
t'as fait tes recherches dans ton porte monnaie? Very Happy .
si il équilibre correctement ça vaut le cout pour 110Euros, c'est sûr.
Message par Pulse Mar 26 Mai 2009 - 13:54
thba66 a écrit:t'as fait tes recherches dans ton porte monnaie? Very Happy .
Pour l'instant je ne l'ai pas trouvé sous 200$ Wink
Message par delichoc45 Mar 26 Mai 2009 - 15:44
J'ai chargé à 3C et mon G3 était bien équilibré. J'ai fait trop peux de charges avec pour le juger mais là j'ai 5 Lipos à charger donc je vais le faire avec le iCharger car pour l'hypérion, on sais tous qu'il équilibre bien Wink
Je relèverai les résultats des équilibrage pour vous informer.
Pour le prix c'est 198$ le tarif normal en effet. moi je l'ai payé 149$ car membre platinuim.. Cool chez Hobby city.
delichoc45
delichoc45
Message par vttman4012 Mar 26 Mai 2009 - 16:39
prend tes mesure au multimetre , les sonde pas chére c vraiment aléatoire !
vttman4012
vttman4012
Nombre de messages : 636
Message par Pulse Mar 26 Mai 2009 - 22:32
delichoc45 a écrit:J'ai chargé à 3C et mon G3 était bien équilibré. J'ai fait trop peux de charges avec pour le juger mais là j'ai 5 Lipos à charger donc je vais le faire avec le iCharger car pour l'hypérion, on sais tous qu'il équilibre bien Wink
Ah tiens t'as aussi des G3! Je n'arrive pas à les trouver en 2S 5000Mah, indisponibles sur tous les sites que j'ai cherché No . Sans indiscrétion tu les as trouvés où?
Franchement je vais attendre tes mesures et continuer à me renseigner pour le chargeur je suis pas au jour près.
T'as pris quoi comme alimentations pour tes chargeurs?
Vous pensez quoi des chargeurs duo type hyperion 0610i duo 2?
Sur l'e-revo que je compte commander il y a 2 compartiments pour les lipos donc il me faudra 2 lipos dans tous les cas pour que les masses restent équilibrées correctement.
Mon objectif c'est à la fois de permettre une charge et un équilibrage parfait des lipos tout en ne perdant pas de temps inutilement. Le duo se justifie à votre avis Question
Message par delichoc45 Mer 27 Mai 2009 - 6:00
J'ai acheté mes G3 chez RCsupersales aux us, j'ai pas eu de douane.
pour les alim j'utilise des 24V en 15A comme les deux chargeur prennent 28v pour l'un et 32V pour l autre, ça chauffe beaucoup moins que du 15V car pour des 6S il n'y a pas besoin d'élever la tension donc moins d'ampères..
tu peux charger 2X3S sur le 208B avec la plaquette d'équilibrage d'origine.
delichoc45
delichoc45
Message par Pulse Mer 27 Mai 2009 - 10:44
Merci Wink
J'hésite toujours entre eos720I et icharger 208b après toutes mes recherches, je n'arrive pas à trancher.
Niveau équilibrage d'après tes mesures le icharger est au niveau du hyperion?
Tu confirmes qu'on peut charger 2 lipos identiques avec un seul et même chargeur non duo?
Message par delichoc45 Jeu 28 Mai 2009 - 19:54
une petite vidéo du 208B on vois les modes et la température du chargeur ( temp inter), il ne chauffe pas.
Sur la deuxième vidéo c'est la fin de charge. 4600mAh en 20 minutes et température chargeur 33° et lipo 25° (température ambiante). Pour ce qui est de équilibrage j'ai 0.008V d'écart maxi sur les 6 éléments et une moyenne de 4,195 ( valeurs du 0720i, confirmé par un voltmètre)
Donc j'ai fait le test sur les 3 lipo G3 et j'ai la même chose pour des charge a 15A donc pour des charges à 1C je pense que c'est encore mieux..
Vidéo n°1
delichoc45
delichoc45
Vidéo n°2 (fin de charge)
delichoc45
delichoc45
Message par Pulse Ven 29 Mai 2009 - 0:57
Excellent les vidéos, 1000 merci Smile. Ce sera vraiment intéressant d'avoir tes conclusions concernant ces 2 chargeurs Cool .
D'après tes premières impressions quels sont les atouts/défauts du 720i et du 208B respectivement?
Message par oliv49 Jeu 3 Sep 2009 - 13:00
Après quelques mois d'utilisation, qu'en est-il du comparatif 720i / 208B ?
Merci.
oliv49
Nombre de messages : 38
Message par Charlie Jeu 3 Sep 2009 - 18:05
je serai bien tenté de changer aussi, des retours sur ces chargeurs? Cool
merci Wink
Charlie
Charlie
Nombre de messages : 46
Message par oliv49 Ven 4 Sep 2009 - 14:12
Un ptit Up
oliv49
Message par oliv49 Sam 5 Sep 2009 - 20:54
Up !
oliv49
Message par hugosxm Sam 5 Sep 2009 - 21:41
Euh salut
vu que personne te repond...
Moi jte donne mon avis :
J ai pas eu ces chargeurs en main mais ca fait un moment que j observe pour acheter et le icharger parait pluss complet et equilibre super bien apres niveau puissance je croit qu il est un pêu plus puissant...
Moi j irai vers le icharger rien que pour le fait que avec tu a la sonde T° et le cable usb de diagnostique...
hugosxm
hugosxm
Nombre de messages : 907
http://jeunepilote.skyblog.com
Message par Fléau Ven 13 Nov 2009 - 17:57
Je sais pas oû ça en ai mais je te conseil le icharge 208!
j'ai le 1010 et j'en suis super content! Il équilibre à merveille.
Je trouve la navigation plus facile que l'hypérion.
Nombre de messages : 5386
http://rcx-team.oldiblog.com
Message par oliv49 Sam 14 Nov 2009 - 14:54
Merci pour l'info, j'ai effectué mon choix il y a 1 mois.
Finalement, j'ai pris un icharger 208 + un alim 24V/25A.
Menu clairs, équilibrage très bon.
Et ça dépote question ampérage, génial avec des G3.
Je le conseille si d'autres sont intéressés.
oliv49
Message par Pulse Sam 14 Nov 2009 - 16:51
Conseiller sans posséder son concurrent n'a pas de sens. J'ai l'hyperion 720I NET3 + alim meanwell + G3 VX et je pourrais dire exactement la même chose..
Message par Fléau Sam 14 Nov 2009 - 16:55
perso j'ai les 2...
Message par oliv49 Lun 16 Nov 2009 - 9:59
Je dis seulement que j'en suis content.
Je n'ai pas dit qu'un tel est mieux qu'un autre. Et c'était juste en réponse à fleau.
A l'époque j'avais relance le post pour avoir plus d'info.
Oliv
oliv49
