chargeur MEGA 400W 20.0A par TURNIGY
Are you ready to charge your packs faster than ever before or are you
looking to take advantage of the new high C charge rate on the new Zippy
and Turnigy battery packs?
The touch sensitive Turnigy Mega 400W is a high power balancing
charger/discharger which can handle up to 6 cells/20A, LiPo/LiFe to 6S and
NiMH/NiCd up to 18S accurately. Bundled with the Turnigy Mega 400W is an
array of charging wires and plugs, suitable for most applications.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing charge & discharge
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
High-power and high-performance circuit
Store function, allows safe storage current
Data storage (Store up to 10 packs in memory)
Cyclic charging/discharging
Spec.
Input voltage: 11.0 – 18.0Volt
Charge current: 0.1 – 20.0A
Discharge current: 0.1 – 5.0A
Maximum charge capacity: 400W @ input voltage >15V
Maximum discharge capacity: 25W
Current drain for balancing Li-po: 200mAh/cell
Lithium (LiPo/LiIo/LiFe) battery cell count: 1 – 6 series
NiCd/NiMH battery cell count: 1 – 18 series
Pb battery voltage: 2 –24V
Battery setup memories: 10
Intelligent temperature control: Yes
Weight: 820g
Dimensions : 152X145X57mm
Including;
1 x Turnigy Mega 400W charger
1 x JST XH Adapter
1 x Banana plug w/ Female Mini JST
1 x Banana plug w/ Female Futaba
1 x Banana plug w/ Aligator clip
1 x Banana plug w/ Losen wires
1 pair Aligator clip
This charger has a JST-XH charge plug, which makes it compatible
with Zippy, HXT,TURNIGY and any pack with a JST adapter.
Note: Power supply not included.
lien http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11340
moi aussi je pense que hyperion a du souci a ce faire si ce qui ai annoncer et vrais
merci truggy france pour cette info et chezoit
Re: chargeur MEGA 400W 20.0A par TURNIGY
Reste à voir ce que donne l'équilibrage.
Mais si l'équilibrage est de bonne qualité, c'est une bonne affaire.
80$
je vais en prendre 3 ou 4
voila les retours sur le chargeur, toujours dans les commentaires que l'on peut lire en bas des pages
je traduit "avec l'aide de chezoit" pour les novices avec peut de moyen comme moi et qui ne parle pas l'english
Citation:
Vous avez mon chargeur aujourd'hui. Je l'ai branché et a commencé l'équilibrage un LiPo 3s5000 juste au-dessus 3 ampères. Tout à coup, après deux minutes, le chargeur "explosé" avec un "big bang", et certains types de fibres volaient autour de lui ...
Citation:
Le chargement d'une batterie 6S 3300mAh Turnigy à 1C (3.3A) le chargeur fonctionne bien, l'équilibre parfait, mais il ne l'odeur un peu chaud. Essayé la batterie prochain à 2C (6.6a) à partir d'un approvisionnement 25A/12V, et après 20 minutes, le chargeur est mort.
Plus de détails à l'adresse:
http://www.helifreak.com/showpost.php?p=2042263&postcount=7
Citation:
WTF!
Brûlés immédiatement. A écrit un commentaire ici et HOBBYCITY éliminé, le.........
et ce ne sont pas les seuls
la plus part ont des odeurs de brulé ou ne chargent pas a plus de 1c ...
FAIRE ATTENTION
lisez bien les........
et désoler a tous ceux qui ce sont empresser de l'acheter pour l'info
je ne rembourse pas
Citation:
Citation:
Citation:
WTF!
FAIRE ATTENTION
je ne rembourse pas
c'est pas chezoit qui a traduit mais moi
on va dire sa laisse un epu septique au niveau de la qualite
62410greg- Nombre de messages : 44
gilou a écrit:c'est pas chezoit qui a traduit mais moi
désoler
kloz24 a écrit:gilou a écrit:c'est pas chezoit qui a traduit mais moi
désoler
grrrr miam
il te manque un mollet
» TURNIGY MEGA 400W fiable ?
» Chargeur Turnigy 400W
» Chargeur turnigy 4x6S 400W
» chargeur Turnigy 4x6S 400W ou autres chargeurs multiports
» Alim pour un chargeur de 400w
