Le Deal du moment :
SSD interne Crucial BX500 2,5″ SATA – 500 ...
29.99 €
Serpent 811Be V2 ref: 600012
Serpent 811Be V2 ref: 600012 Empty Serpent 811Be V2 ref: 600012
Message par magmainger Sam 30 Mar 2013 - 15:10
Serpent après avoir sortie un V2 de son modèle thermique sort la version Be du 811 V2, la ref: 600012 est apparu sur le site officiel Serpent!
Serpent 811Be V2 ref: 600012 12345710
La page officielle: 811Be V2
Les News:
Main new features
- new wider rear end with new geometry for more rear traction and an easier handling car with wider sweetspot
- rear shockabsorbers moved to the back of the shocktower
- longer rear shocks; with longer housing and shockrods for more travel
- rear wing with integrated holders for the ballraced rear anti-roll bar
- longer rear lower arms, new higher carbon shocktower, longer rear shock, new upright
- lexan mud-guards to mount on lower rear arms
- nylon mud-scrapers mount on the rear uprights
- improved differential gears - as already in the Be version
- larger bearings in steeringblocks and uprights 8X16X5 (2) and 15x21x4 (2),
- transmission using larger bearings 8x19x6 and 13x19x4 and new couplers for extra durability –
Donc les principales modifications touchent le train arrière, et le surdimensionnement des roulements des fusées et dans la transmission.
Les Photos:
Serpent 811Be V2 ref: 600012 12345711
Serpent 811Be V2 ref: 600012 12345712
Serpent 811Be V2 ref: 600012 12345713
Serpent 811Be V2 ref: 600012 12345714
Enjoy!!! Serpent 811Be V2 ref: 600012 423367754
Mag'
magmainger
magmainger
Nombre de messages : 214
Serpent 811Be V2 ref: 600012 Empty Re: Serpent 811Be V2 ref: 600012
Message par magmainger Lun 6 Mai 2013 - 12:56
Hello!
Ca commence à être dispo dans les bonnes crèmeries: Wartelle
Mais je crois que j'ai pris le dernier! Rolling Eyes
Mag'
magmainger
magmainger
